LMS 2.6: username minimum length
Answered Question
Jun 29th, 2007
  • Gold, 750 points or more
It's not letting me create a local user with a name fewer than 5 chars.
Validation Error
Invalid username: It should be atleast 5 characters.
Is there any way around that? The ones inherited from LMS 2.2 are fine.
Can I manually stick it in cwpass?
Overall Rating: 5 (2 ratings)
yjdabear Fri, 06/29/2007 - 14:07
Nice to know that method. In a pinch, I manually added a user to cwpass, which turned out alright for my purpose too, without having to restart any process.
yjdabear Mon, 07/02/2007 - 07:10
Does the resetLoginModule.pl script erase the ACS server credentials currently stored?
Is there any way to adjust the timeout value of how long LMS waits for ACS?
I just noticed that when I toggled from TACACS+ (with debug OFF) to CiscoWorks Local, the latter setting got saved with debug ON by default. This was in the non-ACS mode.
Does each instance of SCP to/from a Cisco router/switch take up a VTY line? I'm seeing our MOTD in the list of Partially Successful Config Archive devices:
partial
rtr1 PRIMARY STARTUP Jul 02 2007 02:14:53 SSH: Failed to establish SSH connection to xxx.xxx.xxx.xxx - Cause: Connection refused. TELNET: Failed to establish TELNET connection to xxx.xxx.xxx.xxx - Cause: Connection refused. PRIMARY-STARTUP config Fetch Operation failed for TFTP. Failed to fetch config using SCP.(truncated MOTD banner)
Joe Clarke Mon, 07/02/2007 - 08:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The resetLoginModule.pl script only disables the login module, it does not affect its configuration. The timeout for TACACS+ is hardcoded. Each SCP session does take up a VTY line.
