Rob Huffman Fri, 06/29/2007 - 16:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
The 1230 can be upgraded to LWAPP with the A Radio model listed below;
Solution Requirements
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
All 1130AG access points
All 1240 AG access points
For all IOS-based 1200 series modular access point (1200/1220 Cisco IOS Software Upgrade, 1210 and **1230 AP**) platforms, it depends on the radio:
if 802.11G, MP21G and MP31G are supported
if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
All 1310 AG access points
From this good doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
Hope this helps!
Rob
Naveen Kumar Thu, 09/05/2013 - 10:03
  • Silver, 250 points or more
AIR-AP1232AG-x-K9 (Cisco IOS Software)
AIR-LAP1232AG-x-K9 (Cisco Unified Wireless Network Software)
These products with Cisco IOS Software Release 12.3(11)JX or later  supported Lightweight Mode.
Abhishek Abhishek Wed, 10/16/2013 - 18:38
  • Gold, 750 points or more
You need to download
Cisco Aironet Upgrade Tool for Cisco IOS Software. Utility that upgrades IOS OS to LWAPP and retains current AP configuration. Requires Cisco Aironet Upgrade Image.
CiscoAironet-AP-to-LWAPP-Upgrade-Tool-v34.exe Cisco Aironet Upgrade Tool for Cisco IOS Software. Utility that upgrades IOS OS to LWAPP and retains current AP configuration. Requires Cisco Aironet Upgrade Image.
The link is -
http://software.cisco.com/download/release.html?mdfid=279537740&softwareid=280775089&release=3.4
Leo Laohoo Tue, 10/22/2013 - 14:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Will the cisco 1230 access point work in lighweight mode if it is using a radio?
Depends on what is your WLC.  It doesn't matter if you are using 802.11a radio module or not.
The final firmware version that supports 1230 is 7.0.220.X.  If you have a WLC that supports this firmware, then you are fine.  If you have, for example a WLC 2000 then the answer is "no".
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
