VPN with Cisco client
refram
Level 3
Level 3
I have set up a VPN with a PIX 506 v. 6.3(5). When I connect through the internet using a Cisco VPN client, the connection is made but I can't ping anything behind the firewall.
Just to test, I set up the PIX in a lab, put the public IP of the gateway on my computer and connected the computer to the outside interface of the PIX. I then connected using the VPN client software and I could ping behind the firewall just fine. It's just when I'm going through the internet that it's a problem. My configuration follows:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password **** encrypted
passwd **** encrypted
hostname IPcommPIX
domain-name computerdata.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 172.27.0.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 172.27.0.0 255.255.255.0 172.27.0.16 255.255.255.240
access-list outside_cryptomap_dyn_20 permit ip any 172.27.0.16 255.255.255.240
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside <outside IP> <mask>
ip address inside <inside IP> <mask>
ip audit info action alarm
ip audit attack action alarm
ip local pool CDI1 <range of internal IPs> mask <mask>
pdm location 172.27.0.0 255.255.255.0 outside
pdm location 172.27.0.16 255.255.255.240 outside
pdm history enablearp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 <outside gateway IP> 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 172.27.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup computerdata address-pool CDI1
vpngroup computerdata dns-server 209.x.x.4 4.2.2.2
vpngroup computerdata idle-time 1800
vpngroup computerdata password ********
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
: end
Thoughts?
acomiskey
Level 10
Level 10
add...
isakmp nat-traversal
Please rate helpful posts
5 Replies 5
acomiskey
Level 10
Level 10
add...
Holey Moley! Fast AND fixed the issue. You rock!
Thanks, it's the #1 RA Vpn issue so it's an easy on to pick out.
Okay, so then here's the thing. I'll admit right here in print that I am not a complete "everything-there-is-to-know-about-Cisco-I-know" kind of guy. I didn't do the VPN from scratch, I used the wizard. If this is such a common problem, why isn't the wizard taking it into account? I know, I know, you always ask for it when you use a wizard instead of a CLI. But DUDE! I mean, this apparently happens a lot and it's just one crummy line that fixes the whole thing!
Well thats a good question maybe someone from Cisco can answer. Here's the doc on common vpn problems...
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
