Warning message
Cisco NAC on Dell PE1950
Jun 29th, 2007
I am trying to install the Clean Access Server on a Dell PowerEdge 1950, but have run into an issue. The install works just fine, but after the reboot, I get a kernel panic error:
Kernel panic - not syncing: Attempted to kill init!
Loading mptbase.ko module
Loading libata.ko module
Loading ata_piix.ko module
Creating root device
mkrootdev: label /1 not found
Mounting root filesystem
mount: error 2 mounting ext3
Switching to new root
ERROR opening /dev/console!!!!: 2
error dup2'ing fd of 0 to 0
error dup2'ing fd of 0 to 1
error dup2'ing fd of 0 to 2
unmounting old /proc
unmounting old /sys
switchroot: mount failed: 22
I will attach the full boot log taken from a Hyperterm session. I had a similar problem loading the Clean Access Manager on a Dell PowerEdge 860, but I resolved that by disabling console redirection.
spille Fri, 07/06/2007 - 20:44
I was trying to install 4.1.1, but apparently only the PERC 5/i hdd controllers are supported, not the SAS 5/i. Anyone have any clue how I could still get this to work?
wsaxon Fri, 09/07/2007 - 13:56
I'm having the same issue trying to install 4.1(2) on a PE1950 with the SAS 5/i controller. Although, I do not have any messages after the kernel panic message - i.e. that message occurs last.
