2960 Switch Issue
Jun 29th, 2007
Users connected to my switch complaints slowness or timeout to application server.
Our Application Server looks ok, users on other switch doesnt complaint..
What is the best tool or command-line commands to identify the problem of high utilization or issues on the switch.
royalblues Fri, 06/29/2007 - 23:04
  • Green, 3000 points or more
sh proc cpu would give you the utilization of the switch, but CPU load should not be a problem.
It mostly seems to be a speed/duplex mismatch issue on the uplink port
Check the uplink port status using sh int command for errors and mismatch.
Narayan
mohammedmahmoud Fri, 06/29/2007 - 23:04
First of all check the switch CPU, then check the switch log to see if there is any duplex mismatch or any kind of errors.
HTH,
Mohammed Mahmoud.
Amin Shaikh Fri, 06/29/2007 - 23:35
The swtich has Duplex as FULL and Speed as 100
Utilization of CPU is 10% to 20%
Is there anything else I could check....
mohammedmahmoud Sat, 06/30/2007 - 00:42
Ok, what is the speed/duplex of the server, note that if the server is set to Auto, since the switch is set manually then no autonegotation is going to take place and the server will assume half duplex which will introduce duplex mismatch, which might be your problem.
HTH,
Mohammed Mahmoud.
cisco_lad2004 Sat, 06/30/2007 - 01:11
  • Gold, 750 points or more
what are you suspecting teh switch ? is there any other devices between ur servers and users apart from switch.
other things that can be checked in switch :
1-Error on interfaces.
2-Drops on interfaces.
3-congestion on interfaces (then u should see drops).
4-test with ICMP packets from server to end user to see if u are loosing packets anywhere.
5-are there any spanning tree status changes on logs.
is there anyway to set speed and duplex on server and hard code it ?
Sam
Amin Shaikh Sat, 06/30/2007 - 01:11
I will be replacing the switch today and check with a new switch...
How could I check if a single machine or couple machine connected to the switch are the reason for unstability of the swtich.
cisco_lad2004 Sat, 06/30/2007 - 01:28
Try pings to see if any device the path is dropping packets. then traceroute.
Sam
mohammedmahmoud Sat, 06/30/2007 - 01:38
Can you please check the server speed/duplex issue first before replacing the switch.
HTH,
Mohammed Mahmoud.
