diro Sat, 06/30/2007 - 10:17
  • Bronze, 100 points or more
Normally you can with the range option on the ip address but must be in a continues range i thought you could also use it on ports:
owner virtual_sites
content virtual_rule
vip address 200.200.200.1 range 50
port 80
protocol tcp
add service web1
add service web2
active
RODRGUTI Sat, 06/30/2007 - 19:22
No, in fact we cannot use the range command for ports. We cannot specify a port range under the content rule.
We have 2 options:
1- Configure the content rule without a specific port, like this:
protocol tcp
add service web1
add service web2
active
This content rule will match all the traffic that is comming into the CSS with vip address 200.200.200.1 with any port.
2- Configure a multiple content rules with the same vip address but each one with a specific port like:
content virtual_rule_80
port 80
protocol tcp
add service web1
add service web2
active
content virtual_rule_8080
port 8080
protocol tcp
add service web1
add service web2
active
and so on...
I will suggest you to configure a content rule per port, because if you open a TAC case or you need to do some troubleshooting this will help a lot since we have a more complete and strong configuration.
Both options works, but I would say that option 2 is the best option.
Hope this help.
-Rodrigo.
