SIP-UA behaviour on Cisco ISR router
Jun 30th, 2007
Is there there a way to get the sip-ua in the ISR to react to, for example 5xx or 4xx responses from returned after and INVITE? i.e. can/will the sip-ua fail-over to an alternate host/target returned in DNS SRV resource record on receipt of a 5xx or 4xx response?
ozmark Fri, 07/06/2007 - 01:11
Not so sure my 28xx would a agree with that statement.
dial-peer voice 1003 pots
destination-pattern 0440003
port 0/0/0:3
nat symmetric check-media-src
no remote-party-id
disable-early-media 180
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 2
registrar ipv4: expires 123
sip-server ipv4:
line con 0
jposada_us Fri, 07/13/2007 - 13:30
Do you mean to have an alternate (secundary) target IP in case the first one fail, I have a configuration to do that but not sure if it's what you are looking for.
Let me know
ozmark Mon, 07/16/2007 - 05:51
I would be interested in this. At least to compare with what I have done today with my DNS SRV approach. Unfortunately I have had a TAC running on this for a little while now and I have finally had confirmation that sip-ua in the ISR will only failover to an alternate target up no response i.e. not on receipt of a 503 meessage for example.
jposada_us Mon, 07/16/2007 - 07:12
Not sure about the SIP message 503, I had done this long time ago and it worked with a 2801 even in the no response from fist ip address. Try this configuration...
ip domain name
ip host
dial-peer voice XX voip
description XXX
destination-pattern 00[1-9].......
session protocol sipv2
session target sip-server
codec g729r8 bytes 30
retry invite 2
