xp hyper terminal scrolling problem
Jun 30th, 2007
Does any one know how to set hyper terminal setting so scrolling will be available and won't go wrong?
lamav Sat, 06/30/2007 - 06:53
I have a better idea: Dont use Hyperterminal -- its garbage. Download Putty (its free) or use Secure CRT.
Ofir-Yeshayahu Mon, 07/02/2007 - 12:10
Thanks for your response.
I tried changing the buffer but there is no change. I'm able to see parts of the configuration (after "show run" the first 24 raws ok and the rest go wrong). I'm using vt100 terminal (tried others too):
Unfortunately I have to use only hyper terminal..
