6509 Non E concern
Answered Question
Jun 30th, 2007
I have 6509 non E chassis. Do I have any need for concern if I want to deploy VoIP? Can I deploy the CCM modules andthe IOS to support them in a non E chassis?
Correct Answer by Jon Marshall about 9 years 10 months ago
You can still run the sup720 with the latest IOS on the 6500 non-E chassis and this confgiuration AFAIK will take all the service module cards including yours - i'm assuming you are referring to the CMM module ?
If however you want to power IP phones from the 6500 then yes it may be a concern. Attached is a link to a 6500 Enhanced chassis doc
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd8017a5e7.html
scroll down to table 2 which covers number of phones that can be powered on different chassis.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sat, 06/30/2007 - 09:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
phillip-wright Tue, 07/03/2007 - 08:26
Thanks Jon,
You answered my question, and cleared my concerns. And yes, i was refering to the CMM mods.
