Site to site with an ASA5505 to a Linksys BEFVP41
Answered Question
Jun 30th, 2007
I'm trying to create a site-to-site connection between a ASA5505 and a Linksys BEFVP41. The remote site BEFVP41 connects but I can't get any traffic to the head-office network.
remote = 188.88.9.0 /24
headoffice = 188.88.8.0 /24
Config attached.
Correct Answer by ggilbert about 9 years 6 months ago
Did you get this working. I looked at the config on the ASA and according to what you have stated, it seems that you want to encrypt between 188.88.8.0/24 to 188.88.9.0/24 - But your access-list for encryption states
access-list outside_60_cryptomap extended permit ip 188.88.8.0 255.255.255.0 host 207.216.215.135
This is going to encrypt traffic originating from 188.88.8.0/24 to the host 207.216.215.135
IS that what you want to do?
Is that how it is configured on the linksys side?
Gilbert
Overall Rating: 5 (5 ratings)
Correct Answer
ggilbert Wed, 07/11/2007 - 08:33
Gilbert
bradarmitage Mon, 07/16/2007 - 12:21
Thanks for your reply Gilbert.
I haven't managed to get this going yet.
I do want to encrypt data between 188.88.8.0/24 and 188.88.9.0/24.
How would I go about making the change you suggest?
Thanks B4Hand,
Brad
acomiskey Mon, 07/16/2007 - 12:27
Give gilbert credit for this one...
access-list outside_60_cryptomap extended permit ip 188.88.8.0 255.255.255.0 188.88.9.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 188.88.8.0 255.255.255.0 188.88.9.0 255.255.255.0
bradarmitage Mon, 07/16/2007 - 12:35
Thank-you ever so much for the quick response. I will hopefully get a chance to implement and test this later tonight.
Cheers,
Brad
bradarmitage Tue, 07/17/2007 - 06:09
I applied the suggested solution and it worked like a charm. Thank-you very much for the excellent information.
Cheers,
Brad
ggilbert Tue, 07/17/2007 - 06:15
Adam,
Thanks and
Brad,
I am glad you got it to work.
Cheers,
Gilbert
