NM module not showing up
jdevoll
I have an NM-2E2W inserted into slot 0 in a 3620. When I run a 'show int', no interfaces are seen. I ran a show diag...
show diag
Slot 0:
Fast-ethernet port adapter, 0 ports
Port adapter is disabled
Port adapter insertion time unknown
Hardware revision 0.0 Board revision UNKNOWN
Serial number 0 Part number 00-0000-00
Test history 0x0 RMA number 00-00-00
EEPROM format version 0
EEPROM contents (hex):
0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Does anybody have any ideas of what the problem might be?
paolo bevilacqua
it seems this NM got the "cookie" area zeroed, cannot be recognized and should be RMA if you have a support contract.
Hope this helps, please rae post if it does!
I upgraded IOS, and now show diag at least recognizes the module but the interfaces don't show up in the router.
BBR2# show diag
Slot 0:
Combo 2E, 2W Port adapter, 4 ports
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision E0
Serial number 18804148 Part number 800-01171-05
FRU Part Number: NM-2E2W=
EEPROM format version 1
0x20: 01 1E 01 02 01 1E ED B4 50 04 93 05 00 00 00 00
0x30: 70 00 00 00 00 03 08 17 FF FF FF FF FF FF FF FF
When the router is booting I get the following messages:
smart init is sizing iomem
ID MEMORY_REQ TYPE
000000 UNKNOWN port adapter
000024 0X00019A40 Four port Async/Sync
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X0031E5F0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
It looks like the card isn't supported, but all of the documentation says it is. Any ideas?
