CCNP Simulator
Jul 1st, 2007
Hi all,
Does any know about a good ccnp simulator..apart from Boson ccnp 7.0. A simulator that has the most commands and it is affordable.
suelange Tue, 07/03/2007 - 09:47
Dynamips is good if you have a robust enough PC to run all the emulations or several to spread them across. But the best value for the money is to go to Bryant Advantage,, and rent pod time. He has great labs, easy to understand explanations and you get to use real equipment that behaves exactly like you'd expect. I've learned a lot from his stuff.
