Onnet Calls Connected Party information
Jul 1st, 2007
Hi all,
had a problem with the "connected party" display when Onnet calls is make between two Phones in two CCM clusters via a H323 Gateway.
Can we modified the manipulated "connected party" information(no restricting) to tell the caller party that they are dialing the right number?
I am not modifying any calling party or called party information just the connected party information
dsweeny Fri, 07/06/2007 - 06:13
Try the same with MGCP Gatway it will work fine, h323 gateway with in the cluster you can get Connected Party information.
