access port
Jul 1st, 2007
Here is the senario...
there are 2 access layer switch 1&2 they are connected using access link,on switch1 i have all ports in vlan2 and on switch2 i have all the ports in vlan 10.
will i be able to ping from a system connected to switch1 to system on switch2 the system are in same subnet.
mohammedmahmoud Sun, 07/01/2007 - 02:46
  • Green, 3000 points or more
Although this is a weired setup, but it should work, as the frames are sent untagged on access ports.
HTH,
Mohammed Mahmoud.
vishwancc Mon, 07/02/2007 - 00:32
thanks for the reply..
One more doubt with the access port on both side show up or flap,since they belong to different vlan
mohammedmahmoud Mon, 07/02/2007 - 00:51
As i told you before although this is a weired setup as it makes no sense to connect 2 switches via access ports, they should be connected via trunk ports (in order to be able to handle all the VLANs between the 2 switches), but it should work as the frames are sent untagged on access ports and this shouldn't have any impact on the ports.
HTH,
Mohammed Mahmoud.
