Cisco 7985G device not found in the new phone lists
Jul 1st, 2007
Dear Professionals,
I got stuck in this new device Cisco 7985G IP phone to register in my CallManager 4.1 (3).
I already downloaded and uploaded the firmware for this device to CCM but still I cant find in the option when adding new phone in the list.
I tried stop and restarting the tftp server, the publisher etc. but nothing happened.
Any tip or procedure how can I add this new device to my call manager.
Overall Rating: 5 (3 ratings)
lfulgenzi Sun, 07/01/2007 - 05:46
  • Silver, 250 points or more
Do you have SR1 installed? This document refers to compatibility with SR1. If you don't have that, then it's likely you will need to install the devpack. The DevPack not only installs the firmware on the server (similar to unzipping the files on the server yourself) but updates the SQL database to add all the necessary administrative features to manage the phone.
http://www.cisco.com/en/US/customer/products/hw/phones/ps379/prod_release_note09186a0080838f70.html
You can find the devpack here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser
JUNKSA_2 Sun, 07/01/2007 - 08:05
Thanks for the information. I will install the devpack immediately.
br/jun
Rob Huffman Sun, 07/01/2007 - 06:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jhun,
Just to add a note to Lelio's good info here (5 points for your excellent answer Lelio :)
Whenever you go to the Add New Phone List and the IP Phone Model is not shown this means that the version of CCM that you are running does not yet support this Device-Type. In this case, support for the 7985 was not added until CCM 4.1.3SR1. So you must install the SR/Device Pak to add this model to the list of supported devices. Whenever a new IP Phone model is released that you want to start using this is usually what is required.
I think CCM 4.1.3 is now at SR4d, so have a look at changing to the latest Service Release (SR), this will add support for the 7985 as well as hundreds of Bug Fixes.
Hope this helps!
Rob
JUNKSA_2 Sun, 07/01/2007 - 08:08
Hi Rob,
Excellent information, I will download now the new Service Release that support the 7985.
br/jun
