Where can I get a T3 barrel connector
Jul 1st, 2007
occasionally I have to troubleshoot faults on cisco routers and need to create loopbacks for T3 circuits. Can anyone tell me where I can buy connector for these T3 cables?
mohammedmahmoud Sun, 07/01/2007 - 08:47
  • Green, 3000 points or more
You can arrange it to be done with a technician, you need a 75 ohms coaxial cable with male BNC connectors cross-connected at each end (Rx<->Tx and vice versa), i think that you might also found it at many vendors:
http://www.l-com.com/productcenter.aspx?id=8
HTH,
Mohammed Mahmud.
