Script editor
Answered Question
Jul 1st, 2007
i am wondering if scripts done with version 3.5 will work for IPCC version 4 and vice verca.
please advice.
Good day
Correct Answer by Chris Deren about 9 years 6 months ago
First open it in the 4.0 script editor and the editor will automatically ajust it. Then upload it to the CRS engine.
Chris
Overall Rating: 5 (2 ratings)
Chris Deren Sun, 07/01/2007 - 19:05
You will be able to convert scripts from version 3.5 to 4.0, but not the other way around. If you create a script in version 4.0 IPCC 3.5 will not accept it.
HTH,
Chris
twissam Sun, 07/01/2007 - 22:44
thanks for the info and about converting from 3.5 to 4 it should be automatic or there is another way?
thanks for your help
Good day
Correct Answer
Chris Deren Mon, 07/02/2007 - 03:21
Chris
