C6500 with Netflow
Jul 1st, 2007
Hi All,
Our C6500(Sup2+MSFC2) is NativeOS and version is 12.2SXF(18).
When we configure the command "mls flow ip full" and the C6500 will show "Unable to change flowmask to full-flow because Cx is configured"? We don't know why?
Who have same question or how to resolve it?
mcrichard Tue, 07/03/2007 - 18:22
Hi Thanks your reply
The bug already fixed on 12.2(18)SXF and we used 12.2(18)SXF8.We think it already fixed
Konstantin Dunaev Tue, 07/03/2007 - 22:53
actually it's not a bug I think it's a featue :), and I'm not sure that it will be fixed.
If you use the NAT you can't use full-flow for Netflow because of some internal restrictions: NAT and Netflow uses different flow masks and they are not compatible.:
and here:
