Does Cisco not issue Certificate kit of 646-392 LCSE?
Jul 1st, 2007
I have both passed the papers Cisco foundation express 642-381 and Cisco Lifecycle 646-392 for the requirement of premier partnership, when i log in cisco tracking system i did not find any certificate status, is cisco not issue certificate kit LCSE 646-392? plz help
Overall Rating: 5 (1 ratings)
Your company will receive a Foundation partner kit when all requirements are met.
You as Field Specialist receive a kit when you pass on 642-381. Lifecycle isn't a requirement for the professional. It's a requirement for the company you're associated, thus, no kit for lifecycle.
Hope that clears things a bit.
Please rate the answer if it helped.
kolawole1 Wed, 07/11/2007 - 09:35
of course i appreciate your answer but i would like to know
Once you write the lifecycle exam if you decide to leave the company will cisco remove the partnership from them ?
What will be your status, your future ,can you use the credentials to certify another company
Thanks for rating the answer!
Your Cisco ID (CCO) holds all your exams and certificates. Your employee associates your Cisco ID with them, thus enjoying special partnership benefits.
You can disassociate your Cisco ID from your employee anytime you wish, and you keep all your exams and certificates. You're the expert. ;)
