What does this mean?Supports only l3-ipmulticast addresses - Catalyst 3750
Jul 1st, 2007
What does this message mean?
Switch(config)#mac-address-table static 0100.5e7a.2a01 vlan 301 interface fa 1/0/2
Supports only l3-ipmulticast addresses.
HQIRDMZ2(config)#exit
Show Version:#sh version
IOS (tm) C3750 Software (C3750-I5-M), Version , RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 05-Apr-04 22:06 by antonino
Image text-base: 0x00003000, data-base: 0x009206D8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
HQIRDMZ2 uptime is 19 weeks, 5 days, 12 hours, 7 minutes
System restarted at 01:00:47 AEDT Sun Feb 11 2007
System image file is "flash:c3750-i5-mz.121-19.EA1d/c3750-i5-mz.121-19.EA1d.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision A0) with 118776K/12288K bytes of memory.
Processor board ID CAT0730X011
Last reset from power-on
Bridging software.
1 Virtual Ethernet/IEEE 802.3 interface(s)
24 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0D:65:88:89:00
Motherboard assembly number : 73-8046-05
Power supply part number : 341-0048-01
Motherboard serial number : CAT072903E0
Power supply serial number : LIT071800N7
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3750G-24T-E
System serial number :
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.1(19)EA1d C3750-I5-M
Configuration register is 0xF
astanislaus Sun, 07/01/2007 - 23:16
Please point me to any links / urls that clearly explains why this is happening. I tried this command in my lab switch which is just a 3750 and not a 3750G and this command is accepted.
