WLSE with remote APs
Jul 2nd, 2007
I have a project to realise with autonoumus APs. the APs are places in distant places connected to private network via VSAT.
For my case the need of centralised management with WCS need to support H-REAP this which is not supported with my AP1231G.
I wanna to ask if for remote APs I can use WLSE for that solution and if you have something to expalain how do that.
Thank you (useful replies will be rated)
Overall Rating: 5 (1 ratings)
diro Mon, 07/02/2007 - 10:17
  • Bronze, 100 points or more
Yes you can use the cisco WLSE for remote management of standalone cisco aironets, but there are some requirements:
- cdp for auto discovery (like ciscoworks, lms)
- snmp must be enabled
- need for wds
The features which it offers are:
- Centralized configuration management
- Reporting
- Self Healing
- Sitesurvey / Re-Sitesurvey
- IDS
- Heatmaps
Congig guide:
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_configuration_guide_book09186a008083a0a3.html
There is also a course for the cisco wlse: called wlse 1.0
Trending Topics - Security & Network
