OID for active calls
Jul 2nd, 2007
I'm running a WS-X6608-E1 blade as voice gateway and want to monitor the amount of active calls. To do this manually, I'm using the command "show port voice active", but is there a possibility to query this via snmp?
Overall Rating: 5 (1 ratings)
t.kraemer Tue, 07/03/2007 - 23:23
Thanks, that would be exactly what I have been looking for, but this MIB does not seem to be supported by the WS-X6608-E1 blade, which must be run under CatOS. As workaround, I'll code a small script using the cli.
Pavel Bykov Wed, 07/04/2007 - 04:45
  • Silver, 250 points or more
I like small scripts. A lot of people can be replaced by them :)
