CUE Change Default Language
Jul 2nd, 2007
Hi All
We're running CUE 2.3 (Aim) with US Language. Can anyone tell me how I can change this to UK language?
I've downloaded UK language pack from but it looks to me like I can't simply install the additional language and make that the default. Instead I must reinstall all the software on the module. Is this correct?
Thanks In Advance
rob.huffman Mon, 07/02/2007 - 05:05
Hi Anthony,
Have a look at the method listed at this link that detals changing the CUE Language without losing all existing data;
Frequently Asked Questions
I have a working system and I want to change the language (while saving all the data on the system). Which procedure do I need to follow?
Hope this helps!
