CCM phrase password recovery
Jul 2nd, 2007
I need a help to recover the phrase password, which I lost long back. I am trying to install plug-in Digit analyser, it asked for the phrase password which I dont remember. Please let me know the procedure how to break/recover the same.
Thanks in advance
Overall Rating: 4.5 (2 ratings)
jbarcena Mon, 07/02/2007 - 06:33
To change the password phrase
You can use Adminutility tool to reset the Private password phrase, this tool only runs on
the Publisher and needs to be done after hours since it stops services; here is the path
and the steps to run it.
Log into the utility as Administrator and select the very top checkbox to select all
accounts. Then go to Options and Set new password
It will ask you for the password phrase, and the tool will run, everything keeps working
fine after the tool finishes.
karunanithi Tue, 07/03/2007 - 02:57
Thanks for your reply. It helped me a lot. Please let me know if I change this passwords will it change only phrase password and SQLmanager, etc or SA and private also will change?
