07-02-2007 02:58 AM
I am not able to ping the vip of context oid from the css box as well as from the directly connected segment ie 10.1.22.0
!Active version: sg0720206
configure
!*************************** GLOBAL ***************************
username cisco des-password qgnfwfeayepaphub
cdp run
ip redundancy
ip route 0.0.0.0 0.0.0.0 10.1.24.1 1
!************************* INTERFACE *************************
interface e4
bridge vlan 2
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.1.24.3 255.255.255.192
circuit VLAN2
--More--- ip address 10.1.22.100 255.255.255.192
!************************** SERVICE **************************
service DNS
ip address 10.1.24.15
active
service OcsMail
ip address 10.1.24.22
active
service Proxy
ip address 10.1.24.19
active
service oid1
ip address 10.1.22.79
protocol tcp
keepalive type http
port 8000
active
service oid2
ip address 10.1.22.80
--More--- protocol tcp
keepalive type http
port 8000
active
service oid3
protocol tcp
keepalive type http
port 389
active
service oid4
protocol tcp
keepalive type http
port 389
active
service oid5
protocol tcp
keepalive type http
port 636
--More--- active
service oid6
keepalive type http
protocol tcp
port 636
active
service webserver1
ip address 10.1.24.7
keepalive type http
active
service webserver2
ip address 10.1.24.11
keepalive type http
active
!*************************** OWNER ***************************
owner DNS
content DNS
add service DNS
--More---
owner OcsMail
content OcsMail
add service OcsMail
owner Proxy
content Proxy
add service Proxy
owner oid
content oid
add service oid1
add service oid2
vip address 10.1.22.101
content oid_389
protocol tcp
port 389
add service oid3
add service oid4
vip address 10.1.24.51
--More---
content oid_636
protocol tcp
port 636
add service oid5
add service oid6
vip address 10.1.24.52
owner web
content web
add service webserver1
add service webserver2
vip address 10.1.24.13
protocol tcp
port 80
active
CSS11501#
CSS11501#
CSS11501#
CSS11501#
CSS11501# sh ver
Version: sg0720206 (7.20 Build 206)
Flash (Locked): 7.20 Build 206
Flash (Operational): 7.20 Build 206
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
07-02-2007 02:58 PM
Make sure the content rule you configured is active and after that check that the services are showing up as alive.
