IPCC Standby MSDE/SQL!!!
Answered Question
Jul 2nd, 2007
i have 2 Call Managers version 4.2
i have installed IPCc express on the PUB and did configured it with a cluster profile and all other configs
than i moved to the SUB and installed the IPCC as well joining the same cluster profile. the installation was ok until i begin configuration at the sub, it gives me that IPCC is running on MSDE even though the SQL is installed due to the fact that i have CCM SUB.
please note that i have installed the full IPCC express components on both servers, also note that during the installation of the IPCC it asks if i want to install SQL (which i did not check, since i have the sql already installed because it is co-resident wth CCM), so how can i make sure that the IPCC is installing its configuration on SQL or MSDE and how !!!!!!
do i need additional license for the standby or the one that comes with each (PAK) should work. ultimitly i need to have a standby scenario
please advice.
Correct Answer by Gergely Szabo about 9 years 9 months ago
you cannot have a CCM co-located IPCC Express with High Availability - actually, the reason is the MS SQL server (sort of) special edition that comes from Cisco as CD #4 of the IPCC Express media kit...
Actually, wherever I had a co-located scenario, it just gave me a pain in the neck: performance problems, maximum 10 agents, no HA.
If you want to be on the safe side, just buy two servers and do a clean install of IPCC Express with its own SQL server + HA.
Overall Rating: 5 (1 ratings)
Correct Answer
Gergely Szabo Tue, 07/03/2007 - 02:51
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
twissam Tue, 07/03/2007 - 03:38
yes you are right i was going to post an update before seeing your feedback.
Also to add to your information, we need a license as well for the HA.
Good day
