CRS script upload
Jul 2nd, 2007
Hi all,
I've a problem uploading the CRS script from the administration page, the CRS version is 4.0(4). When I use the "upload new script" link under the Scirp Management page, after the script selection and after the UPLOAD button pression I get the following:
"The page can't be displayed".
The connection toward the LDAP seems ok, also I restarted IIS but I have the same problem.
Does anyone can help me?
Overall Rating: 5 (1 ratings)
Stefano Amici Fri, 07/06/2007 - 04:28
Do you find any solution or workaround?
I'm in the same situation.
tim.giles Wed, 08/06/2008 - 11:37
Hi Stefano,
Thanks for the useful link, I had the same problem today with one of our customers and this worked a treat!
Easy enough process to change the LDAP attributes but I've attached the tool in case anyone needs it....5 points my friend!
