Help with VPN and static NAT to same server
I have a 2811 and I used the SDM to setup the VPN. I have the vpn connected and getting an IP from the scope. I need to get to I also have some static NAT's that connect to the same IP for email and OWA. The system changed my entries to route maps. I can still connect to the static nats but I cannot ping from the VPN to that IP I think it is an access list issue. Also my inbound conections are working but not outbound web traffic.
Here is what I started with before I needed to add VPN
ip nat pool Internet X.X.184.51 X.X.184.51 netmask
ip nat inside source list 1 pool Internet overload
ip nat inside source static tcp 25 X.X.50.214 25 extendable
ip nat inside source static tcp 443 X.X.184.56 443 extendable
ip nat inside source static tcp 4899 X.X.184.60 4899 extendable
Any advise would be helpful.
