Incorrect Unity Password Prompt
Jul 2nd, 2007
  • Bronze, 100 points or more
Unity 4.1 - password requirement is 3 digits but prompts states that 5 is the minimum. If you enter 3 digits for the new password it works just fine, just the prompt is wrong. The client is a bank and some auditors "tightened" permissions. I am guessing this may be the issue. Can you point me in the directions of what account priviledge to check that may be causing this?
Ginger Dillon Mon, 07/02/2007 - 07:58
  • Blue, 1500 points or more
Hi -
In your Unity SA, go to Account Policy, Phone Password Restrictions page. Select the radial button that says "Minimum number of characters in password" and enter 3. Save. The next time your users have to change passwords, the 3 digit length will be enforced. This setting applies to all users.
Ginger
