thisisshanky Mon, 07/02/2007 - 13:09
  • Purple, 4500 points or more
I dont think any of the MPX dvds can be downloaded. You have to buy one of the base versions and upgrade images are available for download.
Ginger Dillon Mon, 07/02/2007 - 14:05
  • Blue, 1500 points or more
Hi -
Your MPE PAK should be on record with Cisco and/or your VAR since these were purchased. Hopefully you also purchased SAU (Upgrade support). I would think you should be able to work thru them and get another copy of the DVDs. Best wishes on that!
Ginger
