MPLS: route injection by radius
Jul 2nd, 2007
Hi.
I have configured a VPN with radius authenticacion. The radius send the IP,the forwarding vrf and the framed route.
The framed-route is inserted directly by the PE in the vrf routing table.
I want to inject a route that must not included int the vrf.
Do you know any method for this? Is it possible?
mheusing Fri, 07/06/2007 - 01:06
  • Cisco Employee,
Can you please explain in more detail, what you mean with "I want to inject a route that must not included int the vrf."?
Which route should or should not be injected where?
Regards, Martin
jyubero Fri, 07/06/2007 - 01:15
Hi Martin.
I want to use the same connection for a vpn and for internet access. The user connects by DSL with radius authentication.
If with the radius profile, i inject the 'ip vrf forwarding ...' (cisco Avpair), then the injected routes are included in the vrf (with framed route or cisco avpair).
Thanks and regards.
Jose
Any method for
