Joe Clarke Mon, 07/02/2007 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You may want to ask this on one of the switching forums so it gets proper visibility.
Jon Marshall Mon, 07/02/2007 - 11:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
No, this should be the only file but to be on the safe side you can enter the command
dir const_nvram:
This should show you the full contents.
Jon
yjdabear Mon, 07/02/2007 - 11:40
  • Gold, 750 points or more
So far I've seen nothing but vlan.dat on const_nvram on the cat6k's, hence the question. I wonder what else could be there.
On a related note, just found out the 3500s had vlan.dat on flash: instead.
Joe Clarke Mon, 07/02/2007 - 11:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, the desktop switches will have vlan.dat on flash:.
