PIX failing over unexpectedly?
Answered Question
Jul 2nd, 2007
We have two PIX515E(failover via serial cable). Ever since we physically relocated the two firewalls, it's been failing over to secondary then back to primary. It happened three times within a span of three months. I verified that there was no trend in the timing of the failover, it just happens sporatically. We do not have Syslog setup yet, so I do not have any logs to attach.
This is what i get with the "sh failover" command:
*PIX Firewall-1*
*//10.10.10.1//*
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
Last Failover at: <time here> PDT <date here>
This host: Primary - Active
Active time: 39630 (sec)
Interface dmz1 (10.10.1.1): Normal
Interface inside (10.10.10.1): Normal
Interface dmz2 (10.10.2.1): Normal
Interface dmz3 (10.10.3.1): Normal
Interface dmz4 (10.10.4.1): Normal
Interface dmz5 (10.10.5.1): Normal
Other host: Secondary - Standby
Active time: 165180 (sec)
Interface dmz1 (10.10.1.2): Normal
Interface inside (10.10.10.2): Normal
Interface dmz2 (10.10.2.2): Normal
Interface dmz3 (10.10.3.2): Normal
Interface dmz4 (10.10.4.2): Normal
Interface dmz5 (10.10.5.2): Normal
Stateful Failover Logical Update Statistics
Link : Unconfigured.
*PIX Firewall-2*
*//10.10.10.2//*
Failover On
This host: Secondary - Standby
Other host: Primary - Active
I was wondering if anyone had any ideas why this is happening.
-Lee
Correct Answer by JBDanford2002 about 9 years 10 months ago
Possibly one of the connected interfaces is losing connectivity to the other PIX. What other devices are connected? Do you have logging on them? Maybe spanning tree problems etc...
Overall Rating: 4 (1 ratings)
Correct Answer
JBDanford2002 Mon, 07/02/2007 - 15:08
lalcantara Tue, 07/03/2007 - 11:58
How simple was that! A few switch ports that the PIX interfaces was plugged into was negotiating incorrectly(duh!). There was a huge amount of collisions/late collisions and deferred packet losses. So I just forced the duplex & speed on the switch ports, until now there are no reported collisions.
Thank you!
