Cannot log into Cisco 2800 router. Please help!
Jul 2nd, 2007
Please help. I can't log into our 2800 router. I tried the using cisco for the username and password, but it doesn't work. How can I tackle this? Is there a way to reset the username and password?
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco".
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
User Access Verification
Username: cisco
Password:
% Login invalid
Username:
Overall Rating: 5 (2 ratings)
djgizmo250 Mon, 07/02/2007 - 14:20
I followed the procedure in the link above. The procedure states that you cannot re-use the encrypted passwords. Is there a way that I can use the same passwords?
rashmi Mon, 07/02/2007 - 21:10
  • Cisco Employee,
I am having the same issue today. I changed teh configuration but didn't change the username and password. so I am stuck. I am not close to the system so I could not try but someone sent me the following message:
You can do password recovery.
Follow the procedure on this link.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
djgizmo250 Tue, 07/03/2007 - 16:45
Thanks for all your help guys! I went through both procedures and it didn't work. I kept getting the same banner and prompt below. I ended up doing a write erase and started fresh.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use
Username: cisco
Password:
% Login invalid
Username:
