CatOS help
Answered Question
Jul 2nd, 2007
I am trying to view the interface configs and vlan assignment for interfaces on a Catalyst 4006 with CatOS but I am unfamiliar with CatOS commands. Can someone point me in the right direction?
-Shikamaru
Correct Answer by Edison Ortiz about 9 years 6 months ago
Since CatOS only functions at Layer2, you will only be able to see arp entries from the VLAN the management interface (sc0) is part of.
The command is show arp.
Correct Answer by Jon Marshall about 9 years 6 months ago
To view the mac address table in CatOS
"sh cam dynamic"
You can also put in specific ports, do a
"sh cam ?"
Jon
Correct Answer by Jagdeep Gambhir about 9 years 6 months ago
Hi Shikamaru,
Here is the command,
Switch> (enable) sh port 3/1
Check this link
http://www.cisco.com/warp/public/473/53.shtml#Show_Port_for_CatOS_and_Show_Interfaces_
Please rate if that helps !
`JG
Overall Rating: 5 (3 ratings)
shikamarunara Mon, 07/02/2007 - 17:52
Is there a way to see the MAC address table and ARP table in CatOS? I found a command that looks like it should give me the information (show port x/y), but it doesn't have any MAC addresses in it. I'd just like to know what IP addresses are connected to each interface.
-Shikamaru
Correct Answer
Jon Marshall Mon, 07/02/2007 - 22:06
"sh cam dynamic"
"sh cam ?"
Jon
Correct Answer
Edison Ortiz Tue, 07/03/2007 - 05:30
