PIX 515 config issues
I know I am missing something here I just can't figure it out.. Something doesn't feel right about this config and I am having issues getting from one inside to dmz and inside to outside randomly. Any tips or suggestions on this config?
Inside should be 192.168.0.0 255.255.0.0 network
dmz is 10.0.0.0 255.255.255.0 network
outside is 65.125.117.96 255.255.255.240 network
inside users need to get to dmz and outside, dns resides outside and on a dmz server also, 2 outside ips 65.125.117.99 and 101 should be natted 10.0.0.3 and .4 each with a few ports being forwarded to them and that is all. Basic config nice and easy and something just seems fishy with it..
vitripat Mon, 07/02/2007 - 18:18
  • Gold, 750 points or more
Keeping in mind your requirements, you dont need to have nat/global rules configured the way they are right now. It seems that you are exhausting the IPs in global pool for outbound access and hence facing issues. Try following-
clear global
no nat (inside) 1 10.0.0.0 255.0.0.0
global (outside) 10 interface
clear xlate
Now test the connectivity. There shouldnt be any connectivity issues from inside->dmz.
Vibhor.
