No ping in pix 506e in password recovery procedure
Jul 2nd, 2007
I was following the procedure for recovering password in pix 506e but something not working when I assign for example
192.168.1.1 for pix and
192.168.1.2 for pc
and connecting them with a cross cable no one of both interfaces can ping to my pc
and my pc wont see them
I need help for this little situation and I will be thankfull for any idea
Fernando_Meza Mon, 07/02/2007 - 22:33
  • Gold, 750 points or more
Hi .. if you have followed the below procedure. Then that is all you need. Just make sure you download the correct .bin file according to the version code you are running. Also make sure you are testing the correct interface .. you could be connecting to another a different interface instead of the one you configured the IP address to or even pehaps the cross over cable could be faulty.
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_password_recovery09186a008009478b.shtml
I hope it helps .. please rate it if it does !!!
