LMS 2.6 and HP Openview 7.5
Answered Question
Jul 3rd, 2007
Does anyone know it LMS 2.6 can integrate with HP Openview Network Node Manager 7.5 ? Or can i install integration utility 1.7 to LMS 2.6 server in order to communication with openview 7.5 ?
Jan
Correct Answer by David Stanford about 9 years 11 months ago
Yes that's right, you can do this with LMS 2.6
Yes, it does integrate with NNM 7.5:
If they are to be on same server, you can download and install Adapter.v1-7.sol.nnm.tar (assuming solaris) to CW box.
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-nnm
(also download readme for directions).
Readme does mentions:
Adapter(Version 1.7) for integrating Cisco Applications and Cisco Devices into HP Network Node Manager 6.4 , 7.0 , 7.01 and 7.5 versions
If you are installing NNM on separate server, you can install the Integration Utility (IU) on the remote server where HP NNM is installed which you may download from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-utility
Overall Rating: 5 (3 ratings)
Correct Answer
David Stanford Tue, 07/03/2007 - 05:32
  • Cisco Employee,
kanokpan Tue, 07/03/2007 - 18:55
Thank you very much.
So I can just install Integration Utility 1.7 into Openview 7.5 without upgrading ciscowork to LMS 3, right ?
Jan.
Correct Answer
David Stanford Tue, 07/03/2007 - 18:59
  • Cisco Employee,
