single SSID and ACS
Jul 3rd, 2007
I would like your help in the following scenario, we currently have a setup of CAS CAM, LDAP, WISM and ACS,
The main point I'm focusing on is the ACS and WISM.
Users are to obtain wireless access using a single SSID, and upon validation of credentials, they should gain access to one of 3 vlans, guest, data and voice, the use of separate SSID per vlan was highly discouraged by customer.
Would appreciate your advice on the best feasible way to implement this.
Overall Rating: 4 (1 ratings)
