Jul 3rd, 2007
I have 2 switches 1&2 on switch 1 i have trunk port with encapsulation 802.1q and native vlan 5 ,this switch is connect to switch 2 to port that is in
access mode and on vlan 10.
i have user on switch 1 in vlan 10 and there are also user on switch 2 on vlan 2 .
My question
1.Will the link come up (no DTP is running)
2.If the link come up with the vlan 10 user able to communicate with vlan 10 user on other switch
Thanks in advance guys...
royalblues Tue, 07/03/2007 - 02:42
Have a look at the attached scenarios which are from the BCMSN book
It will clarify all your doubts
HTH, rate if it does
Pavel Bykov Tue, 07/03/2007 - 02:57
Native VLAN 5 and ACCESS 10 will not establish trunk, and VLAN's 5 and 10 will be interconnected. I.E. Users from VLAN 5 on one switch will communicate with users in VLAN 10 in the other switch.
NATIVE vlan 5 and ACCESS vlan 10 means that frames for those VLANs are sent untagged, therefore as normal ethernet traffic in a broadcast domain.
vishwancc Tue, 07/03/2007 - 03:14
well as far as i know the link will come up ,do you have any document to help me out here.
