GUI on CME4.0 with CUE general question
Jul 3rd, 2007
when logging on to the GUI using http:/x.x.x.x/Web as a general user. There is a
Search > Local Directory Search
option on the menue, however it just shows a list of extensions and names but no search facility is this correct or do i have a problem with GUI?
Colin
paolo bevilacqua Tue, 07/03/2007 - 05:57
  • Hall of Fame,
    Founding Member
Hi again Colin,
it's not you that have a problem, it's the GUI that have a problem in delivering features :)
ReadersUK Tue, 07/03/2007 - 08:01
Thanks again, its very disapointing, i think it would be better if this was not shown in the gui and not raise expectations.
colin
