ip nat inside source list VRF
Jul 3rd, 2007
I have a Cisco 7204VXR with a NPE175 and 64 MG. I am using the IOS c7200-js-mz.122-32.bin. My problem is that I cannot form the VRF in "ip nat inside source list 2 interface loopback 2 vrf XXXXX overload". The commando vrf does not appear to me. An example:
interface Loopback2
ip vrf forwarding PRUEBA
ip address 10.10.10.10 255.255.255.255
Cisco7200(config)#ip nat inside source list 2 interface loopback 2 vrf PRUEBA overload
% Invalid input detected at '^' marker.
Cisco7200(config)#ip nat inside source list 2 interface loopback 2 ?
overload Overload an address translation
<cr>
So that I cannot form the VRF?
I must have another version of IOS?
Cheers
palmanet2007 Wed, 07/04/2007 - 06:50
Hi, Thanks for your aid.
The problem is that I only have 64 Mg and all the IOS require 128.
you know some IOS that has supported VRF Aware NAT and it only needs 64 Mg to work?
Cheers
mohammedmahmoud Wed, 07/04/2007 - 11:38
  • Green, 3000 points or more
Hi Eusebio,
Unfortunately you need at least 128M to support this feature on your platform.
HTH,
Mohammed Mahmoud.
