Problem with logged-in users
Jul 3rd, 2007
I am using ACS 4.1 for W2K and i have some problems to purge logged in users. Whe i want to do this action the message "No users at IP x.x.x.x" appears. Until now i have about 300 users which i can't remove from the "Logged-in Users" list. I didn't have the problem with ACS 3.3.3.
Is it possible to purge the users from the command-line?
Overall Rating: 5 (1 ratings)
craig.eyre Fri, 10/03/2008 - 15:19
Do you have to install 4.1.3 first before installing the and then patch 12, or can you go directly from Is 4.1.3 and free upgrade from 4.1.1 or do I need to purchase it?
