Performance of new ASA5510: Is this typical outside data?
Jul 3rd, 2007
I have a new ASA5510 in place and it is working well. Thanks to all the support in the forums that have helped me perform the feat.
I have remote sites that typically loose printers through Citrix. They logon to the server via https.
The ASA5510 was one step in eleminating this interruption. Can someone tell me if the data looks typical or is there some cause for concern?
Interface outside, Collision Counts
"ASA Time (UTC)","Output Errors (packets)","Collisions (packets)","Late Collisions (packets)"
7/3 07:36:12,0,34209,27677
7/3 07:36:22,0,34209,27677
7/3 07:36:32,0,34209,27678
7/3 07:36:42,0,34209,27679
7/3 07:36:52,0,34215,27682
7/3 07:37:02,0,34216,27682
7/3 07:37:12,0,34216,27682
7/3 07:37:22,0,34216,27684
7/3 07:37:32,0,34216,27684
7/3 07:37:42,0,34217,27684
7/3 07:37:52,0,34217,27684
7/3 07:38:02,0,34221,27686
7/3 07:38:12,0,34222,27686
7/3 07:38:22,0,34223,27689
7/3 07:38:32,0,34225,27691
7/3 07:38:42,0,34227,27692
7/3 07:38:52,0,34227,27692
7/3 07:39:02,0,34228,27692
7/3 07:39:12,0,34228,27693
7/3 07:39:22,0,34230,27694
7/3 07:39:32,0,34233,27696
7/3 07:39:42,0,34235,27697
7/3 07:39:52,0,34235,27697
7/3 07:40:02,0,34235,27697
7/3 07:40:12,0,34235,27697
7/3 07:40:22,0,34237,27698
7/3 07:40:32,0,34239,27698
7/3 07:40:42,0,34241,27698
7/3 07:40:52,0,34241,27698
7/3 07:41:02,0,34242,27698
7/3 07:41:12,0,34243,27698
7/3 07:41:22,0,34243,27698
7/3 07:41:32,0,34243,27698
7/3 07:41:42,0,34243,27698
7/3 07:41:52,0,34243,27698
7/3 07:42:02,0,34244,27698
7/3 07:42:12,0,34246,27700
7/3 07:42:22,0,34246,27701
7/3 07:42:32,0,34247,27702
7/3 07:42:42,0,34249,27702
7/3 07:42:52,0,34250,27702
7/3 07:43:02,0,34250,27702
7/3 07:43:12,0,34250,27703
7/3 07:43:22,0,34250,27703
7/3 07:43:32,0,34250,27703
7/3 07:43:42,0,34250,27703
7/3 07:43:52,0,34250,27703
7/3 07:44:02,0,34250,27703
7/3 07:44:12,0,34253,27705
7/3 07:44:22,0,34254,27705
7/3 07:44:32,0,34255,27705
7/3 07:44:42,0,34257,27708
Interface outside, Packet Errors
"ASA Time (UTC)","CRC (packets)","Frame (packets)","Input Errors (packets)","Runts (packets)","Giants (packets)","Deferred (packets)"
7/3 07:34:52,0,0,0,0,0,119192
7/3 07:35:02,0,0,0,0,0,119192
7/3 07:35:12,0,0,0,0,0,119194
7/3 07:35:22,0,0,0,0,0,119194
7/3 07:35:32,0,0,0,0,0,119197
7/3 07:35:42,0,0,0,0,0,119202
7/3 07:35:52,0,0,0,0,0,119204
7/3 07:36:02,0,0,0,0,0,119206
7/3 07:36:12,0,0,0,0,0,119211
7/3 07:36:22,0,0,0,0,0,119212
7/3 07:36:32,0,0,0,0,0,119213
7/3 07:36:42,0,0,0,0,0,119213
7/3 07:36:52,0,0,0,0,0,119227
7/3 07:37:02,0,0,0,0,0,119229
7/3 07:37:12,0,0,0,0,0,119229
7/3 07:37:22,0,0,0,0,0,119233
7/3 07:37:32,0,0,0,0,0,119233
7/3 07:37:42,0,0,0,0,0,119236
7/3 07:37:52,0,0,0,0,0,119238
7/3 07:38:02,0,0,0,0,0,119252
7/3 07:38:12,0,0,0,0,0,119255
7/3 07:38:22,0,0,0,0,0,119259
7/3 07:38:32,0,0,0,0,0,119265
7/3 07:38:42,0,0,0,0,0,119269
7/3 07:38:52,0,0,0,0,0,119270
7/3 07:39:02,0,0,0,0,0,119273
7/3 07:39:12,0,0,0,0,0,119275
7/3 07:39:22,0,0,0,0,0,119279
7/3 07:39:32,0,0,0,0,0,119290
7/3 07:39:42,0,0,0,0,0,119293
7/3 07:39:52,0,0,0,0,0,119293
7/3 07:40:02,0,0,0,0,0,119295
7/3 07:40:12,0,0,0,0,0,119295
7/3 07:40:22,0,0,0,0,0,119298
7/3 07:40:32,0,0,0,0,0,119302
7/3 07:40:42,0,0,0,0,0,119305
7/3 07:40:52,0,0,0,0,0,119305
7/3 07:41:02,0,0,0,0,0,119306
7/3 07:41:12,0,0,0,0,0,119310
7/3 07:41:22,0,0,0,0,0,119310
7/3 07:41:32,0,0,0,0,0,119315
7/3 07:41:42,0,0,0,0,0,119316
7/3 07:41:52,0,0,0,0,0,119316
7/3 07:42:02,0,0,0,0,0,119317
7/3 07:42:12,0,0,0,0,0,119322
7/3 07:42:22,0,0,0,0,0,119323
7/3 07:42:32,0,0,0,0,0,119325
7/3 07:42:42,0,0,0,0,0,119330
7/3 07:42:52,0,0,0,0,0,119333
7/3 07:43:02,0,0,0,0,0,119333
7/3 07:43:12,0,0,0,0,0,119333
7/3 07:43:22,0,0,0,0,0,119334
7/3 07:43:32,0,0,0,0,0,119335
7/3 07:43:42,0,0,0,0,0,119335
7/3 07:43:52,0,0,0,0,0,119336
Overall Rating: 5 (1 ratings)
acomiskey Tue, 07/03/2007 - 08:14
  • Green, 3000 points or more
Looks like a lot of collisions to me, check speed and duplex settings.
Sluggofish Tue, 07/03/2007 - 08:47
Can you please point me in the right direction? The two NICs are teamed, each is a 1GB adapter.
Operating Mode is 1000 Mhps Full Duplex (Copper)
Interrupt 24
Bus [Driver] = [2] 9
I am out of my element here.
acomiskey Tue, 07/03/2007 - 09:41
What device is the server plugged into?
Sluggofish Tue, 07/03/2007 - 10:28
SBS2003 with Team Nic (2 x 1GB) is connected into ASA5510. Also present on the network is a Cisco ASA 2600 series. The 2600 is doing the conversion between the frame relay serial connection and the Ethernet that the ASA utilizes.
Win2003 is plugged into router switch.
Is this what you mean?
Sluggofish Tue, 07/03/2007 - 10:44
