JORGE RODRIGUEZ Tue, 07/03/2007 - 07:42
  • Green, 3000 points or more
Hi Susan,
These are two different platforms.
You can always create a notepad script with all information needed, then configure your new 2801.
Jorge
RiverStatesLAX Tue, 07/03/2007 - 07:47
Is there documentation out there that can help me create the script?
Thanks, Susan
JORGE RODRIGUEZ Tue, 07/03/2007 - 07:52
just login to your 1721 router, could be by console local connection or by telnet.
Do you have access to the 1721 router?
if you do login to it and do
show running-config
the configuration will show in text, you can copy the text and paste it into notepad in windows, when I say script it is text.
