suggestion of configuration for antenna of 5dbi
Jul 3rd, 2007
Hi all
I have a AP 1231 with 5dbi omni antenna, the problem is that the cover it?s very short, is smaller to 20 meters in area with few points of interference.
I need help to solve this situation.
attach the AP config
version 12.3
no service pad
hostname AP_Mongavi
enable password
ip subnet-zero
no aaa new-model
dot11 ssid Extrusiones
vlan 3
authentication open
dot11 ssid GV1
vlan 1
authentication open
dot11 ssid Telephony
vlan 2
authentication open
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
encryption vlan 2 key 1 size 128bit 0 AABB01BA32112CCACBABCD1234 transmit-key
encryption vlan 2 mode wep mandatory
encryption vlan 1 key 1 size 128bit 7 14A78813B903D720B8E3F0B7D518 transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 3 key 1 size 128bit 0 BBBBAAAACCCC11114444CCCC22 transmit-key
encryption vlan 3 mode wep mandatory
ssid Extrusiones
ssid GV1
ssid Telephony
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2422
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0.1
description RED DATOS
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
description RED VOZ
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
description RED Extrusiones
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
description RED VOZ
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 192.168.10.5 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login
line vty 5 15
login
end
scottmac Tue, 07/03/2007 - 19:06
  • Green, 3000 points or more
A couple things come to mind:
Some early generations of 1200s (some 1231) had the connections reversed between teh radio and the antenna terminals. So, even though the terminal is labled "Left," it was really wired as "Right."
Try connecting the antenna to the other terminal and check your signal strengths again. You could also change your settings on the AP to the other side ... either one should (move the antenna to the other terminal or change the setting to the other side) give you an idea.
If that's not it, then it takes us to a discussion of antenna radiation patterns.
As you increase the gain on the antenna, the radiation pattern stops looking like a fat donut and starts looking more like a cone.
What used to be touched by the donut is no longer touched by much of the cone (lower signal strength off the beam).
Try repositioning the antenna, try tipping it upside-down, try sideways. The only way to get passive gain from an antenna is to bend, fold, spindle, or mutilate the beam to concentrate more of it in a specific direction or plane.
If you didn't do a site survey to map all this out, you can spend a fortune trying to find the right antenna to do the job.
Certainly it's possible that one antenna, one AP is not enough to cover the area.
Without a survey, there is no definite way to tell.
Good Luck
Scott
