How do I apply a static route to a specific interface?
Answered Question
Jul 3rd, 2007
I have a default route 0.0.0.0 but I'd like some packets that come in on certain interfaces to have a different default route.
Correct Answer by acomiskey about 9 years 7 months ago
If you only wanted 192.168.1.0/24 to use the specific default route on a particular interface, something like this should work.
interface FastEth...
ip policy route-map mymap
access-list 10 permit ip 192.168.1.0 0.0.0.255
route-map mymap permit 20
match ip address 10
set ip default next-hop
Wow, this seems to be a popular answer.
Overall Rating: 5 (1 ratings)
Amit Singh Tue, 07/03/2007 - 08:20
Roland,
You can use PBR and match the intresteing traffic using an ACL to have it source routed to a different next hop IP. This way your specific incmoing traffic an interface will be policy routed to a different next hop router and the other traffic which doesnot match the PBR will follow the normal defualt route.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/qos_c/qcpart1/qcpolicy.htm
HTH,Please rate if it does.
-amit singh
Correct Answer
acomiskey Tue, 07/03/2007 - 08:21
match ip address 10
