Route calls to a determinated port based on the extension number
I'm trying to route the calls made by the extension 18 to a determinated port. For example if the extension 18 dial 0977xxxxx the call have to go to the port 3/1 and the if the extesions 1x dial 0977xxxx have to go to the port 3/0
Based on the cisco document
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con20
I made this config:
voice translation-rule 6
rule 1 /^0/ /77/
voice translation-profile prova2
translate called 6
dial-peer voice 5 pots
description Trucades Exterior
translation-profile outgoing 5
destination-pattern 0T
direct-inward-dial
port 3/0
dial-peer voice 6 pots
destination-pattern 77T
direct-inward-dial
port 3/1
dial-peer voice 567 voip
translation-profile incoming prova2
answer-address 18
when the extension 18 dial 0977xxx, the call goes out to the port 3/0.
As you can see on this document:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
answer-address have more priority than destination-pattern.
I tried to apply the translation-profile direct to the ephone-dn without success.
Gerard
Overall Rating: 3 (1 ratings)
paolo bevilacqua Tue, 07/03/2007 - 10:30
  • Hall of Fame,
    Founding Member
Hi Gerard,
In fact you may have problems with translation-profile applied to ephone-dn, sometime these don't work.
And, DP voip with answer-address will never work, because the actual incoming DP is one automatically created by ephone-dn.
So, to associate an FXO port to an extension, use the command "trunk" in ephone-dn mode.
It is in the CCME command reference.
paolo bevilacqua Wed, 07/04/2007 - 07:20
  • Hall of Fame,
    Founding Member
I'm afraid it is, you could try anyway.
On the other hand, which IOS are you using? The translation-profile method should work as well modulo any bug.
paolo bevilacqua Wed, 07/04/2007 - 07:50
  • Hall of Fame,
    Founding Member
Once you are there, please try also 12.4(11)XJ3 for translation-profile under ephone-dn. This release fixes many many bugs in telephony.
a.gooding Wed, 07/04/2007 - 16:45
  • Bronze, 100 points or more
Not too sure if this might help but i configured something like this for private lines on a T1. basically i did the same as above but in the route pattern i inserted the prefix as well.
therefore, when extension X dials a number it hits the route pattern with say 28 as the prefix and then matches the relevant DP with 28T (in my case) and then goes through that port. i also restricted it for that extension alone to use that port by using CSS and Partition to associate only with that extension
paolo bevilacqua Wed, 07/04/2007 - 16:50
  • Hall of Fame,
    Founding Member
Hi A.
This is about CME, not CCM.
