NAT not working
Jul 3rd, 2007
I have a 3845 router in which I'm trying to Nat an inside address. I've set up the NATs just like the other ones on this router. When I do a debug I don't see NAT translation occuring what I do is:
Jul 2 21:07:38.464 UTC: NAT: map match BIJ-nat
what does this mean? I'm assuming that my NAT isn't working as I don't see the translation occuring. When I do a show ip nat translation I do see it in there. Any advice would be great....thank you
wgranada1 Tue, 07/03/2007 - 10:55
Sure here it is:
ip nat inside source static 205.248.197.120 172.21.63.48 route-map BIJ-nat extendable
sh ip nat trans
Pro Inside global Inside local Outside local Outside global
--- 172.21.63.48 205.248.197.120
sundar.palaniappan Tue, 07/03/2007 - 11:50
Can you post the configuration of route-map BIJ-nat. What the real address of the device you are initiating the communication from and to what address?
wgranada1 Thu, 07/05/2007 - 10:39
Here is the config:
route-map BIJ-nat permit 10
match ip address BIJ-nat
ip access-list extended BIJ-nat
permit ip any 198.212.155.0 0.0.0.255
permit ip any 66.54.251.0 0.0.0.255
The real IP address is 205.x.x.120
Jon Marshall Thu, 07/05/2007 - 12:08
So the destination address is a host in one of the two networks in your BIJ-nat access-list ? ie.
198.212.155.0 255.255.255.0
66.54.251.0 255.255.255.0
Jon
wgranada1 Thu, 07/05/2007 - 12:30
Yes the destination is actually the 66.54.251.244 address but when I do a debug
I'm looking to see if the original IP of 205.248.197.120 nats to 172.21.63.48 but I never see that when take place. So I was just wondering why....
