07-03-2007 10:30 AM - edited 03-14-2019 10:23 PM
hi
i want to connect to a voip provider i have 7815 MCS and 2811 router with 1 M internet connection speed i want to add a SIP trunk link to this provider assume their target IP is 194.22.3.1 and udp port 5060
what steps do i need to configure this on both CCM 5.1 and 2811 router note that i have just to direct international calls through this link with all other calls to be terminated through another 2811 mgcp VGW ?
please help
07-03-2007 10:34 AM
note that the 2811 in this case would be an IP-to-IP gateway (aka SBC) that requires a special image and license. So if could do so that the CCM trunks directly to the SIP provider, it would be probably be much easier.
07-03-2007 10:37 AM
i just want to direct sip trunk to this voip provider, ip-ip GW is not my case ?!
07-03-2007 12:16 PM
If you do the direct trunk to the provider, the 2811 does the router and knows nothing about the calls, and is not an IP-to-IP gateway.
07-03-2007 09:34 PM
can any one else help pleaaaase
thanks in advance
07-04-2007 01:53 AM
For one step suggest you try to improve attitude and perhaps open the manual at the section "SIP trunking" :)
Best luck!
07-04-2007 03:04 AM
i think forum is for knowledge sharing from one who has knowledge to one who seeks knowledge
any way thanks for "SIP trunking" u could say to me google it.... it will be better!!
07-04-2007 03:10 AM
No, not google it. CCO search, powered by google :)
The point is that you didn't even done your due diligence in reading the manual, and are looking for others to solve your problem.
That pairs well with your attitude at ranking.
Once again, best luck!
07-04-2007 03:28 AM
i did CCOed it, the CCO powered by google, but did not get it
could u please send the link to me
again its not a my problem it is a knowledge sharing...
i hope everyone use forum for knowledge sharing not just only to collect points
07-04-2007 03:47 AM
Here's the link.
I don't care about ratings, but fairness, I do care.
